The OpenBuilds BlackBox uses an FTDI USB Interface chip.
In order to use it on your computer, you may need to install device drivers.
If it fails to install USB drivers automatically, you can download and install the drivers for your operating system from FTDI
USB DRIVER INSTALL
Windows 7/8/8.1/10/11:
Download CDM212364_SETUP.ZIP
Alternately you can check on the manufacturers website at https://ftdichip.com/drivers/vcp-drivers/ for more up to date versions
Mac / Linux / Other Windows versions: Refer to https://ftdichip.com/drivers/vcp-drivers/
TURN SUSPEND MODE OFF
docs/blackbox-x32/install-drivers.txt · Last modified: 2022/11/23 17:56 by admin
