docs:blackbox-x32:connect-nema17
3.2.1 Connecting BlackBox X32 to NEMA17 Motors
IMPORTANT WARNING: Note: Never connect/disconnect motors to a powered-up controller. Always turn off power before connecting/disconnecting accessories to/from your BlackBox
Note if you are not using OpenBuilds Motors, refer to FAQ: Identify Motor coils to identify the coil pairs. The color codes shown below only apply to OpenBuilds Motors
docs/blackbox-x32/connect-nema17.txt · Last modified: 2022/08/19 17:41 (external edit)
