Sidebar
  • OpenBuilds® Documentation
    • OpenBuilds Interface
      • 1. OpenBuilds Interface - Product Tour
      • 2. Connect your Interface
        • 2.1.1 Prepare your BlackBox
          • Prepare BlackBox 4X v2.3 - v2.7
        • 2.1.2 Connect Interface to BlackBox
          • Connect Interface to BlackBox 4X
          • Connect Interface to BlackBox X32
      • 3. Initial Setup
        • 3.1 Firmware Update
          • Method 1: Update via CONTROL
          • Method 2: Update via the Internet/Wifi
          • Method 3: Update via USB Flashdrive
        • 3.2 Prepare USB Flash drive and Setup Wifi
      • 4. Usage Instructions:
        • 4.1 Run a Job
        • 4.2 Probing
        • 4.3 Configuration
        • 4.4 Upload Gcode over Wifi
      • 5. Frequently Asked Questions
        • 5.1 Format Flashdrive as FAT32
        • 5.2 Connect to other Grbl controllers
        • 5.3 Firmware Flashing Error: Not enough space / Flash too Small
        • 5.4 Run/Flash Jumper
        • 5.5 Device Test Mode
        • 5.6 Retrofit older Interfaces for X32
      • 6. Tips and Tricks
        • 6.1 Stacking your Interface onto your BlackBox
docs:interface:sidebar
          • Prepare BlackBox 4X v2.7
          • Prepare BlackBox 4X v2.3 - v2.6
      • 3. Initial Setup
        • 3.1 Prepare USB Flash drive and Setup Wifi
        • 3.2 Firmware Update
          • Method 1: Update via the Internet/Wifi
          • Method 2: Update via USB Flashdrive
          • Method 3: Update via CONTROL
        • 4.1 Run a Job
        • 4.2 Probing
        • 4.3 Configuration
docs/interface/sidebar.1713899119.txt.gz · Last modified: 2024/08/05 15:15 (external edit)
  • Old revisions
  • Backlinks
  • Back to top
  • Log In
  • Media Manager
  • Sitemap
