docs:interface:firmware-error-partitions
Firmware Update Error: Flash Too Small / Not Enough Space
If you encounter the following errors while trying to update firmware, you will have to Reflash your Interface using CONTROL: As the firmware evolves over time, we sometimes may have to release an update that cannot be performed online or via the USB drive method, as it requires flashing the Partition table as well.
  • Flash too Small
  • Not enough Space
Affected firmware versions
  • v1.24 - v1.41 flashing to v1.43 or newer requires you to flash V1.43 or newer using OpenBuildsCONTROL first.
Method
Refer to https://docs.openbuilds.com/doku.php?id=docs:interface:firmware-update-control , make sure you are flashing V1.44 or later
docs/interface/firmware-error-partitions.txt · Last modified: 2024/08/05 15:15 (external edit)
