Use the supplied RJ11 to SL cable that came with your OpenBuilds BlackBox X32, to connect the AUX port on your BlackBox, to the BlackBox port on your Interface:
NEXT: Configure WIFI
docs/interface/connect-blackbox-x32.txt · Last modified: 2023/02/21 20:39 by admin
