docs:interface:start
Order your OpenBuilds Interface
OpenBuilds® Interface Specifications
  • Standalone Human-Machine Interface for controlling your OpenBuilds BlackBox / Grbl based CNC machine
  • No computer required: Plug in a flashdrive with your G-Code files and run directly from the Interface
  • 240Mhz 32-bit Xtensa Dual-Core Microprocessor
  • Supports FAT32 Flash Drives
  • Color TFT LCD display
  • Capacitive Touch buttons, with tactile and audible feedback
  • Supports Homing, Jogging, Probing, Zeroing and Running your CNC machine
  • Plug-and-play with OpenBuilds BlackBox motion controller
  • Can be used with any Grbl 1.1 based controller, which has RX/TX/GND/5V pins (may require you to make your own cabling)
NEXT: Product Tour
docs/interface/start.txt · Last modified: 2020/12/11 19:38 by admin
