docs:interface:wifi-upload
4.4 OpenBuilds Interface: Upload GCODE over Wifi
You can upload GCODE files wirelessly to you OpenBuilds Interface:
Prerequisites:
Before you can use this feature, make sure you have
  • Connected your Interface to Wifi
  • Updated your Firmware (Keep up to date regularly)
Access the Upload page
1) On the LCD it shows the IP address
2) Type that into a web browser and use the big “Upload a GCODE file” button to select the file you want to send.
Note: It can be a little slow - depending on the file size, walking over and fetching the USB drive may be faster
docs/interface/wifi-upload.txt · Last modified: 2023/06/19 12:33 by admin
