docs:blackbox-x32:start
OpenBuilds® BlackBox X32 Specifications
  • Plug and Play easy connections that work directly with the OpenBuilds® Xtension wiring ecosystem
  • 4 x High Powered 4.0A (Peak) Stepper Drivers
  • Up to 1/32nd Microstepping (Defaulted to 1/8 for higher torque)
  • Build in Cooling solution / through airflow design
  • Easy current adjustment
  • Capable of full 2/3/4-axes motion control
  • Dual configurable onboard Relays for Plasmas, Spindles, etc
  • Router (Enable) and VFD Spindle (Direction, Enable, 0-10v) Supported
  • PWM Output for Lasers
  • Servo Output for Pen Plotters
  • Up to 24v 5A Switched Output for Coolant or LED devices
  • 3x Optocoupled Endstop Inputs with power supply (5/24v) suitable for passive or active mechanical, optical and inductive switches
  • 1x Optocoupled XYZ Probe Input
  • Door sensor input
  • USB Interface for Plug and Play
  • WIFI Support
  • SD Card Support
  • High performance 32 Bit Processor
  • Easy V-Slot/C-Beam compatible mounting
  • Dimensions: 171mm (Mounting flange included) x 80mm x 36.4mm
  • Supported by OpenBuilds CONTROL software and all major CAM workflows
  • Powered by highly customizable and configurable GrblHAL Firmware
docs/blackbox-x32/start.1675453122.txt.gz · Last modified: 2024/08/05 15:15 (external edit)
