docs:blackbox-x32:iot-and-laser
6.4 Connecting both an IOT Switching Relay for a Router, and a Laser, to the BlackBox
If you would like to fit both a spindle and a laser to your machine:
  • Grbl only has one PWM output
  • Easiest method to share this signal between multiple tools, it so add a Single Pole, Double Throw switch to direct the PWM signal between the two devices
  • This can also act as a Laser Disarm switch, preventing the laser from firing (safety)
Wiring is as follows:
  • PWM from BlackBox, to COMMON pin of switch
  • PWM out from one side of the switch, to PWM IN on the Laser Module
  • PWM (ON/OFF, as the IoT doesn't support PWM) to the control input on the IoT
  • You can substitute the IoT Relay with Router for other PWM toolheads - the concept remains the same, the switch directs which tool sees the PWM signal from the BlackBox
Software / Firmware:
6.4.1 Connection Diagram
docs/blackbox-x32/iot-and-laser.1660930046.txt.gz · Last modified: 2024/08/05 15:15 (external edit)
