WINDOWS USB DRIVER INSTALL
Download Microsoft Windows drivers from: https://github.com/OpenBuilds/OpenBuilds-DRIVERS/releases/download/latest/openbuilds_usb_drivers_1.0.0.0.exe
Once downloaded, run the Installer and Install the Drivers. This single installer covers all our devices
APPLE USB DRIVER INSTALL
MacOS should already include Drivers as of MacOS 10.15
docs/blackbox-x32/install-drivers.1713988138.txt.gz · Last modified: 2024/08/05 15:15 (external edit)
