{{fa>windows|Windows}} WINDOWS USB DRIVER INSTALL
Download Microsoft Windows drivers from: https://github.com/OpenBuilds/OpenBuilds-DRIVERS/releases/download/latest/openbuilds_usb_drivers_1.0.0.0.exe
Once downloaded, run the Installer and Install the Drivers. This single installer covers all our devices
{{fa>apple|Apple}} APPLE USB DRIVER INSTALL
MacOS should already include Drivers as of MacOS 10.15
TURN SUSPEND MODE OFF
docs/blackbox-x32/install-drivers.1713988087.txt.gz · Last modified: 2024/08/05 15:15 (external edit)
