USB DRIVER INSTALL : BlackBox X32 V1.4 onwards
Download and Install the SiLabs USB Driver to enable your BlackBox X32 to run on your computer
Download Microsoft Windows drivers from: https://www.silabs.com/documents/public/software/CP210x_VCP_Windows.zip
Download Apple MacOS drivers from https://www.silabs.com/documents/public/software/Mac_OSX_VCP_Driver.zip
USB DRIVER INSTALL : BlackBox X32 V1.0 to V1.3
Download and Install the FTDI USB Driver to enable your BlackBox X32 to run on your computer
TURN SUSPEND MODE OFF
docs/blackbox-x32/install-drivers.1708459031.txt.gz · Last modified: 2024/08/05 15:15 (external edit)
