USB DRIVER INSTALL
BlackBox X32 V1.4 onwards
Download Microsoft Windows drivers from: **https://www.silabs.com/documents/public/software/CP210x_VCP_Windows.zip**
Download Apple MacOS drivers from **https://www.silabs.com/documents/public/software/Mac_OSX_VCP_Driver.zi**p
BlackBox X32 V1.0 to V1.3
TURN SUSPEND MODE OFF
docs/blackbox-x32/install-drivers.1708458723.txt.gz · Last modified: 2024/08/05 15:15 (external edit)
