USB DRIVER INSTALL
BlackBox X32 V1.4 onwards
Download Windows 10/11 drivers from: https://www.silabs.com/documents/public/software/CP210x_VCP_Windows.zip Download Apple MacOS drivers from https://www.silabs.com/developers/usb-to-uart-bridge-vcp-drivers?tab=downloads
BlackBox X32 V1.0 to V1.3
TURN SUSPEND MODE OFF
docs/blackbox-x32/install-drivers.1708458544.txt.gz · Last modified: 2024/08/05 15:15 (external edit)
