docs:blackbox-x32:faq-bootloader
Place BlackBox X32 into Bootloader Mode
Introduction
If CONTROL is unable to automatically reset your BlackBox X32 into Bootloader mode during a Firmware Flashing operation, it may ask you on-screen to Enter bootloader mode and then to try again:
This is the procedure you should apply:
Reset into Bootloader Mode
We will use the two buttons on the front of the BlackBox X32, to put the BlackBox X32into “bootloader” mode - this is a special mode in which the BlackBox X32 waits to receive a firmware update from CONTROL
  • Hold down the MODE button keep holding it down (This will tell the controller to be in FLASH mode when it resets)
  • Click the RESET button (This resets the controller, so it can boot up into Bootloader mode - it will check MODE is being held down to know whether to go into Bootloader Mode)
  • Let go of the MODE button
docs/blackbox-x32/faq-bootloader.1714411271.txt.gz · Last modified: 2024/08/05 15:15 (external edit)
