docs:blackbox-x32:faq-bootloader
Place BlackBox X32 into Bootloader Mode
Make sure to download and install the latest version of OpenBuilds CONTROL.
We will use the two buttons on the front of the BlackBox X32, to put the BlackBox X32into “bootloader” mode - this is a special mode in which the BlackBox X32 waits to receive a firmware update from CONTROL
  • Hold down the MODE button keep holding it down (This will tell the controller to be in FLASH mode when it resets)
  • Click the RESET button (This resets the controller, so it can boot up into Bootloader mode - it will check MODE is being held down to know whether to go into Bootloader Mode)
  • Let go of the MODE button
docs/blackbox-x32/faq-bootloader.1714411100.txt.gz · Last modified: 2024/08/05 15:15 (external edit)
