docs:blackbox-x32:connect-rc-servo
3.3.6 BlackBox X32 RC Servo
Wiring
OpenBuilds BlackBox provides support for using an RC servo to raise/lower a pen, in Pen Plotter type applications, or other imaginative uses
Configuration
Calibration
OpenBuildsCONTROL includes a tool to calibrate the Pen Up / Pen Down positions of your Servo. Please perform this step prior to trying out the Pen Up / Down values, and also note down the S-Values as advised by the Calibration Tool to use in your CAM setups later on.
Go to Wizards and Tools > Calibration > Calibrate Servo Pen Up / Down:
docs/blackbox-x32/connect-rc-servo.1675797014.txt.gz · Last modified: 2024/08/05 15:15 (external edit)
