docs:blackbox-x32:connect-psu
3.1 Connecting BlackBox X32 to Power Supply Bundle (OpenBuilds PowerCase on a Meanwell LRS350 24v)
3.1.1 NB: Set the 115/230v Switch
3.1.2 Connecting OpenBuilds PowerCase on a Meanwell LRS350 24v to the BlackBox X32
IMPORTANT WARNING No 2: Please note, double check your Polarity - wiring a BlackBox with reversed polarity will destroy it. Also never work on wiring of any sorts while power is on. Double check all wiring before turning on the power supply in case any mistakes were made.
IMPORTANT WARNING: Please note, we recommend Meanwell Power supplies to ensure the safety and reliability of your BlackBox. Good quality power supplies ensure good, clean power to the controller. Avoid power supplies marketed as “LED power supplies” as they tend to lack filtering/protection circuitry, that can result in fatal power surges that can destroy your BlackBox. Use of other power supplies may affect your warranty.
docs/blackbox-x32/connect-psu.1719571997.txt.gz · Last modified: 2024/08/05 15:15 (external edit)
