docs:blackbox-x32:connect-plasma
3.3.4 Connecting BlackBox X32 to an Air Plasma Inverter, with Z Touchoff Switch
TIP: Set the Relay Function Jumper to M3/M5 mode to use the relay as a plasma trigger switch
docs/blackbox-x32/connect-plasma.1660930889.txt.gz · Last modified: 2024/08/05 15:15 (external edit)
