docs:blackbox-x32:connect-micro-limit
3.4.2 Connecting BlackBox X32 to Limit Switches
Use a 2-core cable to wire up our regular microswitches
IMPORTANT WARNING: Note: Incorrect wiring can short V+ to GND causing damage to your controller: Double check wiring before powering on. We recommend using 2-core wiring only for this type of switch to avoid accidentally shorting V+. Only connect SIG and GND pins on the BlackBox.
Make sure to set [code]$5=7[/code] to use Normally Open switches with grblHAL on the BlackBox X32
If you need a more EMI proof solution, consider upgrading to OpenBuilds Xtension Limit Switches
Micro Limit Switches
Lever Micro Limit Switches
docs/blackbox-x32/connect-micro-limit.1670436223.txt.gz · Last modified: 2024/08/05 15:15 (external edit)
