docs:blackbox-x32:connect-door-sensor
3.6 Connecting BlackBox X32 to a Door Sensor (Machine Enclosures) (Advanced)
OpenBuilds BlackBox supports the door-ajar detection features available in Grbl. In order to activate this feature, ensure you run a custom compiled version of GrblHAL that has this feature enabled. It is not available in the default Grbl configuration.
Note: This is an advanced feature, specific to machines with an enclosure, and not required for everyday use.
docs/blackbox-x32/connect-door-sensor.1661366252.txt.gz · Last modified: 2024/08/05 15:15 (external edit)
