docs:blackbox-x32:connect-coolant
3.7 Coolant Output
The Coolant output is primarily used to control chip-evacuation, dust-extraction or cutting fluid systems, but can also be creatively repurposed for other switching requirements.
It can be controlled with M-Codes:
  • M8 = On
  • M9 = Off
3.7.1 Electrical Specifications
  • Max Current: 3A
  • Voltage: 24v (Same as Input voltage)
3.7.2 Connect OpenBuilds LED Ring
You can use the Coolant output to switch any other 24v device as well, as an example, you can connect your OpenBuilds Spindle LED Ring as shown to put it under M-Code control (for example if you want a Job to turn the LED ring on at the start and off at the end, you can add an M8 to the header and an M9 to the footer of your g-code)
3.7.3 Connect 24VDC Air Solenoid
You can switch 24v Solenoids using the Coolant output. Typically you'd use this configuration in-line between an Air-compressor and a Nozzle pointed at the endmill. Compressed air blowing on the endmill will help evacuate chips from the cut, and keep the endmill cool
docs/blackbox-x32/connect-coolant.1661365940.txt.gz · Last modified: 2024/08/05 15:15 (external edit)
