docs:interface:wifi-setup-nextgen
OpenBuilds Interface: Initial Setup: WIFI and Supporting Files
In order to fully utilize your OpenBuilds Interface you need to configure the Flashdrive(s) you want to use with the Interface by copying our supporting files onto the Flashdrive This wizard also allows you to configure the Wifi Network you want your Interface to connect to.
1. Insert the USB drive into your computer
Insert the USB drive you want to use with Interface into your computer
TIP: Repeat these steps for any other flashdrives you intend using with CONTROL, to ensure the supporting files are present on the flashdrive when you use it with Interface.
2. Download and install OpenBuilds CONTROL
Download and install the latest version of OpenBuilds CONTROL from https://software.openbuilds.com
3. Run the Wizard from OpenBuilds CONTROL
Start OpenBuilds CONTROL, and launch the wizard from Wizard and Tools > Prepare USB Flashdrive for Interface
4. Copy the supporting files and Configure Wifi details
Inside the Wizard, select the correct Controller from the list, Configure your Wifi Details (optional if you do not want to use Wifi but highly recommended) and select the USB drive to copy to.
Then click “Copy supporting files to Flashdrive”
5. The log will show when the copying process has been completed
6. Safely Remove the Flashdrive
Eject / Safely Remove the Flashdrive from your computer, and insert it into the OpenBuilds Interface USB socket.
NEXT: Usage Instructions
docs/interface/wifi-setup-nextgen.1713900370.txt.gz · Last modified: 2024/08/05 15:15 (external edit)
