docs:interface:wifi-setup-nextgen
OpenBuilds Interface: Initial Setup: WIFI and Supporting Files
Connecting your OpenBuilds Interface to your Wifi network, allows it to check for updates, and let you know when an update is available. You can also use the Wifi network to download updates when it suits you, without even needing access to a computer. We highly recommend you set up Wifi on your Interface, as it will ensure you have easy access to the latest firmware and software features, and in the future will also enable extra functionality from your Interface
docs/interface/wifi-setup-nextgen.1713899057.txt.gz · Last modified: 2024/08/05 15:15 (external edit)
