docs:interface:prepare-blackbox
2.1.1 Prepare BlackBox for communicating with Interface
The following instructions cover the neccesary steps to configure an OpenBuilds BlackBox to talk to an OpenBuilds Interface via the AUX serial port on the BlackBox.
Note this section is split into sections, based on the version of BlackBox you have:
On some versions you can peek in through the side vent holes and see the version numbers without removing the cover, if not, you can remove the top panel of your BlackBox, the version numbers are printed on the Brains board inside:
For example:
Check what version you have, and follow the relevant section to prepare your BlackBox
docs/interface/prepare-blackbox.txt · Last modified: 2024/08/05 15:15 (external edit)
