Order Cable BlackBox X32 to INTERFACE (Retrofit RJ11 to Molex SL-4 Cable)
Order Cable BlackBox X32 to INTERFACE (RJ12 to RJ12 Cable)
Connect the Interface port on your BlackBox, to the BlackBox port on your Interface:
IMPORTANT NOTE No 2: Make sure to update your Interface to V1.57 Firmware or later for X32 Support
NEXT: Update Interface Firmware
docs/interface/connect-blackbox-x32.1718649848.txt.gz · Last modified: 2024/08/05 15:15 (external edit)
