Order your OpenBuilds BlackBox X32 Motion Control System Order Cable BlackBox X32 to INTERFACE (Retrofit RJ11 to Molex SL-4 Cable) Order Cable BlackBox X32 to INTERFACE (RJ12 to RJ12 Cable)
NEXT: Configure WIFI
docs/interface/connect-blackbox-x32.1718648252.txt.gz · Last modified: 2024/08/05 15:15 (external edit)
