2.1.2.1 BlackBox X32 Interface V1.7 or newer
2.1.2.2 BlackBox X32 to an older Interface V1.3/V1.5/V1.6
NEXT: Configure WIFI
docs/interface/connect-blackbox-x32.1718627496.txt.gz · Last modified: 2024/08/05 15:15 (external edit)
