Use the RJ11-to-SL cable or newer RJ12-to-RJ12 cable (depending on the versions of the devices you own), to connect the AUX port on your BlackBox, to the BlackBox port on your Interface:
Note picture does not show the newer RJ12-RJ12 cable at this time, but that is straight forward to plug in, instead of the older 4 pin connector.
NEXT: Configure WIFI
docs/interface/connect-blackbox-x32.1701725372.txt.gz · Last modified: 2024/08/05 15:15 (external edit)
