Use the RJ11-to-SL cable or newer RJ12-to-RJ12 cable (depending on the versions of the devices you own), to connect the AUX port on your BlackBox, to the BlackBox port on your Interface:
NEXT: Configure WIFI
docs/interface/connect-blackbox-x32.1700857803.txt.gz · Last modified: 2024/08/05 15:15 (external edit)
