Use the supplied RJ11 to SL cable that came with your OpenBuilds BlackBox X32, to connect the AUX port on your BlackBox, to the BlackBox port on your Interface:
NEXT: Configure WIFI
docs/interface/connect-blackbox-x32.1677011968.txt.gz · Last modified: 2024/08/05 15:15 (external edit)
