IMPORTANT NOTE No 2: Make sure to update your Interface to V1.57 Firmware or later for X32 Support
Use the supplied RJ11 to SL cable that came with your OpenBuilds BlackBox X32, to connect the AUX port on your BlackBox, to the BlackBox port on your Interface:
NEXT: Configure WIFI
docs/interface/connect-blackbox-x32.1675283025.txt.gz · Last modified: 2024/08/05 15:15 (external edit)
