docs:blackbox-4x:connect-plasma
3.3.4 Connecting BlackBox 4X to an Air Plasma Inverter, with Z Touchoff Switch
TIP: Set the Relay Function Jumper to M3/M5 mode to use the relay as a plasma trigger switch
docs/blackbox-4x/connect-plasma.txt · Last modified: 2024/08/05 15:15 (external edit)
