Sidebar
  • OpenBuilds® Documentation
    • OpenBuilds BlackBox 4X
      • OpenBuilds BlackBox 4X - Product Tour
      • 1. Assembling BlackBox
        • 1.1 Assembly Instructions
        • 1.2 Assembly Video
      • 2. Configuring BlackBox
        • 2.1 Jumper Settings
          • 2.1.1 Slave Axis Driver
          • 2.1.2 Limit Switch Voltage
          • 2.1.3 Onboard Relay
          • 2.1.4 RGB Logo Backlight (Advanced)
          • 2.1.5 Autoreset (Advanced)
        • 2.2 Stepper Driver Settings
          • 2.2.1 Current Adjustment
      • 3. Connecting BlackBox
        • 3.1 Connect Power Supply
        • 3.2 Connect Motors
          • 3.2.1 NEMA17s
          • 3.2.2 NEMA23s
          • 3.2.3 NEMA23s (Reversed Y2)
        • 3.3 Connect Tool
          • 3.3.1 Dewalt DWP611 / RoutER11 & IOT Relay
          • 3.3.4 Plasma Cutter
          • 3.3.6 RC Servo
        • 3.4 Connect Limit Switches
          • 3.4.3 NPN Inductive Sensors
        • 3.5 Connect Probe
        • 3.6 Connect Door Sensor
        • 3.7 Coolant Output
      • 4. Drivers and Software
        • 4.1 Install Device Drivers
      • 5. Advanced Configurations
        • 5.1 AUX1 Serial Header
        • 6.4 Using a Laser and IoT Relay - Switchover
docs:blackbox-4x:sidebar
          • 3.2.1 NEMA17s
          • 3.2.2 NEMA23s
        • 3.3 Connect Tool
          • 3.3.6 RC Servo
        • 3.5 Connect Probe
docs/blackbox-4x/sidebar.txt · Last modified: 2024/08/05 15:15 (external edit)
  • Old revisions
  • Backlinks
  • Back to top
  • Log In
  • Media Manager
  • Sitemap
