docs:blackbox-4x:jumper-limitswitchvoltage
2.1.2 Set your Endstop Voltages
OpenBuilds BlackBox can provide power to your endstops: Please use the jumpers to configure the voltage your endstops need: 5v would be suitable for most mechanical and optical switches. 24v would be great for inductive sensors. Check your endstops' datasheets to determine which voltage would suit them better.
5V Endstops: Set the "Limit V+" Jumper to the 5V Setting
24V Endstops: Set the "Limit V+" Jumper to the 24V Setting
docs/blackbox-4x/jumper-limitswitchvoltage.txt · Last modified: 2024/08/05 15:15 (external edit)
