docs:blackbox-4x:install-drivers
The OpenBuilds BlackBox uses an FTDI USB Interface chip.
In order to use it on your computer, you may need to install device drivers.
  • More modern operating systems may be able to use the Blackbox directly without additional drivers,
If it fails to install drivers automatically, you can download and install the drivers for your operating system from FTDI
Windows 7/8/8.1/10/11: Download CDM212364_SETUP.ZIP or check on the manufacturers website at https://ftdichip.com/drivers/vcp-drivers/ for more up to date versions
Mac / Linux / Other Windows versions: Refer to https://ftdichip.com/drivers/vcp-drivers/
PS: Don't forget to Disable USB Selective Suspend on Windows machines
docs/blackbox-4x/install-drivers.1660930005.txt.gz · Last modified: 2024/08/05 15:15 (external edit)
