docs:blackbox-4x:connect-dewalt-iotrelay
3.3.1 Connecting BlackBox 4X to Dewalt DWP611 / RoutER11 Router via IOT Switching Relay Power Strip
You can install an IOT Relay to control your spindle using Gcode commands
M3 S1000 ; Turn Spindle On
M5 ; Turn Spindle Off
If you would like to use both a Laser, and the IoT relay, See: Connecting both an IOT Switching Relay for a Router, and a Laser, to the BlackBox
3.3.1.1 Connection Diagram
NB: Do not plug anything else into the IoT relay (leave the Normally On and Always On sockets disconnected). ONLY connect the Router to the Normally Off socket as shown.
3.3.1.2 Video
docs/blackbox-4x/connect-dewalt-iotrelay.txt · Last modified: 2024/08/05 15:15 (external edit)
