Firstly, install the Drivers: https://docs.openbuilds.com/doku.php?id=docs:blackbox-x32:install-drivers
If it still fails to connect, go to Edit Device Settings:
Make sure your Baud Rate is 115200, and you can try with and without DTR Signal (Enabled seems to work best for the BlackBox X32)
