- Electronics
- CNC Software
- Mechanical
- Tips and Tricks
Machine Type | Travel / Working Area | Max depth of cut | Drive System | Machine Accuracy | Footprint |
LEAD 1515 ![]() | X Axis: 46“ (1170) Y Axis: 49” (1250mm) Z Axis: 3.5“ (~90mm) | ~ 2.5” (~60mm) based on 1/2“ spoiler board | Lead Screw Driven | 0.001” ~0.003“ (0.05mm ~0.10mm) | ~ 60” x 60“ (1500mm x 1500mm) |
LEAD 1010 ![]() | X Axis: 29” (730mm) Y Axis: 32“ (810mm) Z Axis: 4” (100mm) | ~ 2“ (47mm) based on 1/2” spoiler board | Lead Screw Driven | 0.001“ ~0.003” (0.05mm ~0.10mm) | ~ 40“ x 40” (1000mm x 1000mm) |
LEAD 1010 High-Z ![]() | X Axis: 29“ (730mm) Y Axis: 32” (810mm) Z Axis: 12“ (300mm) | ~ 8” (200mm) based on 1/2“ spoiler board | Lead Screw Driven | 0.001” ~0.003“ (0.05mm ~0.10mm) | ~ 40” x 40“ (1000mm x 1000mm) |
C-BEAM ![]() | X Axis: 13.5” (350mm) Y Axis: 11“ (280mm) Z Axis: 1.250” (31.75mm) | ~ 2“ (47mm) based on 1/2” spoiler board | Lead Screw Driven | 0.001“ ~0.003” (0.05mm ~0.10mm) | ~ 21.5“ x 20” (546mm x 500mm) |
MiniMill ![]() | X Axis: 4.5“ (120mm) Y Axis: 7” (180mm) Z Axis: 3“ (80mm) | ~ 2.25” (60mm) based on 1/2“ spoiler board | Lead Screw Driven | 0.001” ~0.003“ (0.05mm ~0.10mm) | ~ 22” x 16“ (560mm x 406mm) |
ACRO 1515 ![]() | X Axis: 50” (1300mm) Y Axis: 50“ (1300mm) Z Axis: 0” (0mm) | ~ 0.25“ (6mm) | Belt Driven GT2 | 0.001” ~0.003“ (0.05mm ~0.10mm) | ~ 60” x 60“ (1500mm x 1500mm) |
ACRO 1510 ![]() | X Axis: 50” (1300mm) Y Axis: 30“ (800mm) Z Axis: 0” (0mm) | ~ 0.25“ (6mm) | Belt Driven GT2 | 0.001” ~0.003“ (0.05mm ~0.10mm) | ~ 60” x 40“ (1500mm x 1000mm) |
ACRO 1010 ![]() | X Axis: 30” (800mm) Y Axis: 30“ (800mm) Z Axis: 0” (0mm) | ~ 0.25“ (6mm) | Belt Driven GT2 | 0.001” ~0.003“ (0.05mm ~0.10mm) | ~ 40” x 40“ (1000mm x 1000mm) |
ACRO 510 ![]() | X Axis: 12” (300mm) Y Axis: 30“ (800mm) Z Axis: 0” (0mm) | ~ 0.25“ (6mm) | Belt Driven GT2 | 0.001” ~0.003“ (0.05mm ~0.10mm) | ~ 20” x 40“ (500mm x 1000mm) |
ACRO 55 ![]() | X Axis: 12” (300mm) Y Axis: 12“ (300mm) Z Axis: 0” (0mm) | ~ 0.25“ (6mm) | Lead Screw Driven | 0.001” ~0.003“ (0.05mm ~0.10mm) | ~ 20” x 20“ (500mm x 500mm) |
