| SKU / Image | Name | Flutes | Shank Diameter | Cut Diameter | Cutting Height | Feed Rate | Plunge Rate | Cut Depth | Degree | Tip | Overall Length | Coating | Best used for |
SB-1018-DC | 1 Flute Upcut Solid Carbide 1/8“ Diamond Carbon | 1 | 1/4” / 6.35mm | 1/8“ / 3.175mm | 5/16” / 7.9mm | 80IPM / 2000mm/min | 25IPM / 600mm/min | 0.0312“ / 0.792mm | 2 -1/2” / 63.5mm | DC | Plastic, Soft Metals | ||
SB-0514-DC | 1 Flute Upcut Solid Carbide 1/4“ Diamond Carbon | 1 | 1/4” / 6.35mm | 1/4“ / 6.35mm | 3/4” / 19.5mm | 80IPM / 2000mm/min | 25IPM / 600mm/min | 0.0625“ / 1.588mm | 2 -1/2” / 63.5mm | DC | Plastic, Soft Metals | ||
SB-10518-DC | 2 Flute Upcut Solid Carbide 1/8“ Diamond Carbon | 2 | 1/4” / 6.35mm | 1/8“ / 3.175mm | 1/2” / 12.7mm | 80IPM / 2000mm/min | 25IPM / 600mm/min | 0.03125“ / 0.794mm | 2 -1/2” / 63.5mm | DC | Plastic, Soft Metals | ||
SB-1018-DC | 2 Flute Upcut Solid Carbide 1/4“ Diamond Carbon | 2 | 1/4” / 6.35mm | 1/4“ / 6.35mm | 3/4” / 19.5mm | 80IPM / 2000mm/min | 25IPM / 600mm/min | 0.0625“ / 1.588mm | 2 -1/2” / 63.5mm | DC | Plastic, Soft Metals | ||
SB-7014-DC | 3 Flute High Helix Solid Carbide 1/4“ Diamond Carbon | 3 | 1/4” / 6.35mm | 1/4“ / 6.35mm | 3/4” / 19.5mm | 80IPM / 2000mm/min | 25IPM / 600mm/min | 0.0625“ / 1.588mm | 2 -1/2” / 63.5mm | DC | Plastic, Soft Metals | ||
SB-8516-NS | 2 Flute Upcut Solid Carbide Ball Nose 1/16“ Nano Shield | 2 | 1/4” / 6.35mm | 1/16“ / 1.58mm | 1/4” / 6.35mm | 30IPM / 750mm/min | 10IPM / 250mm/min | 0.0154“ / 0.391mm | 2 -1/2” / 63.5mm | NS | Wood | ||
SB-1518-NS | 2 Flute Upcut Solid Carbide Ball Nose 1/8“ Nano Shield | 2 | 1/4” / 6.35mm | 1/8“ / 3.175mm | 1/2” / 12.7mm | 50IPM / 1300mm/min | 15IPM / 375mm/min | 0.0312“ / 0.794mm | 2 -1/2” / 63.5mm | NS | Wood | ||
SB-9014-NS | 2 Flute Upcut Solid Carbide Ball Nose 1/4“ Nano Shield | 2 | 1/4” / 6.35mm | 1/4“ / 6.35mm | 1/2” / 12.7mm | 50IPM / 1300mm/min | 15IPM / 375mm/min | 0.0625“ / 1.588mm | 2 -1/2” / 63.5mm | NS | Wood | ||
SB-2014-NS | 2 Flute Downcut Solid Carbide 1/4“ Nano Shield | 2 | 1/4” / 6.35mm | 1/4“ / 6.35mm | 3/4” / 25.4mm | 80IPM / 2000mm/min | 25IPM / 600mm/min | 0.0625“ / 1.588mm | 2 -1/2” / 63.5mm | NS | Wood | ||
SB-2518-NS | 2 Flute Downcut Solid Carbide 1/8“ Nano Shield | 2 | 1/4” / 6.35mm | 1/8“ / 3.175mm | 1/2” / 12.7mm | 80IPM / 2000mm/min | 25IPM / 600mm/min | 0.0312“ / 0.794mm | 2 -1/2” / 63.5mm | NS | Wood | ||
SB-6518-NS | 10 Flute Diamond Cutter Carbon Fiber Solid Carbide Nano Shield | 10 | 1/4“ / 6.35mm | 1/8” / 3.175mm | 3/4“ / 19.5mm | 60IPM / 1500mm/min | 30IPM / 750mm/min | 0.0312” / 0.794mm | 2 -1/2“ / 63.5mm | NS | Carbon Fiber | ||
SB-10014-NS | 2 Flute Straight Solid Carbide 1/4” Nano Shield | 2 | 1/4“ / 6.35mm | 1/4” / 6.35mm | 3/4“ / 19.5mm | 80IPM / 2000mm/min | 25IPM / 600mm/min | 0.0625” / 1.588mm | 2 -1/2“ / 63.5mm | NS | Plastic | ||
SB-9518-NS | 2 Flute Straight Solid Carbide 1/8” Nano Shield | 2 | 1/4“ / 6.35mm | 1/8” / 3.175mm | 1/2“ / 12.7mm | 80IPM / 2000mm/min | 25IPM / 600mm/min | 0.0312” / 0.794mm | 2 -1/2“ / 63.5mm | NS | Plastic | ||
SB-8014-NS | 2 Flute Compression Solid Carbide Bit 1/4” Nano Shield | 2 | 1/4“ / 6.35mm | 1/4” / 6.35mm | 7/8“ / 22.2mm | 40IPM / 1000mm/min | 20IPM / 500mm/min | 0.0625” / 1.588mm | 2 -1/2“ / 63.5mm | NS | Laminates | ||
SB-4000530-NS | Engraving Bit Solid Carbide 30 Degree | 1 | 1/4” / 6.35mm | 0.440“ / 11.2mm | 40IPM / 1000mm/min | 20IPM / 500mm/min | 0.004” / 0.1mm | 30° | 0.005“ / 0.1mm | 2 -1/4” / 57.15mm | NS | Plastic, Wood, Soft Metal | |
SB-4502545-NS | Engraving Bit Solid Carbide 45 Degree | 1 | 1/4“ / 6.35mm | 0.272” / 7.0mm | 40IPM / 1000mm/min | 20IPM / 500mm/min | 0.003“ / 0.079mm | 45° | 0.025” / 0.05mm | 2 -1/4“ / 57.15mm | NS | Plastic, Wood, Soft Metal | |
SB-11514-NS | 3 Flute V Groove Solid Carbide 60 Degree 1/4” Nano Shield | 3 | 1/4“ / 6.35mm | 1/4” / 6.35mm | 7/32“ / 5.6mm | 40IPM / 1000mm/min | 20IPM / 500mm/min | 0.0625” / 1.588mm | 60° | 2“ / 50.8mm | NS | Wood | |
SB-3060 | 2 Flute V Groove Solid Carbide 60 Degree | 2 | 1/4” / 6.35mm | 1/2“ / 12.7mm | 7/16” / 11.1mm | 40IPM / 1000mm/min | 20IPM / 500mm/min | 0.125“ / 3.175mm | 60° | 2” / 50.8mm | N/A | Wood | |
SB-3590 | 2 Flute V Groove Solid Carbide 90 Degree | 2 | 1/4“ / 6.35mm | 1/2” / 12.7mm | 3/8“ / 9.5mm | 40IPM / 1000mm/min | 20IPM / 500mm/min | 0.125” / 3.175mm | 90° | 2“ / 50.8mm | N/A | Wood | |
SB-603254-DC | 3 Flute Ball Nose Solid Carbide Tapered 1/32” Diamond Carbon | 3 | 1/4“ / 6.35mm | 1” / 25.4mm | 40IPM / 1000mm/min | 20IPM / 500mm/min | 0.0078“ / 0.198mm | 6.2° | 1/32” / 0.8mm | 2 -1/2“ / 63.5mm | DC | Plastic, Soft Metals | |
SB-603254-NS | 3 Flute Solid Carbide Tapered Ball Nose 1/32” Nano Shield | 3 | 1/4“ / 6.35mm | 1” / 25.4mm | 40IPM / 1000mm/min | 20IPM / 500mm/min | 0.0078“ / 0.198mm | 6.2° | 1/32” / 0.8mm | 2 -1/2“ / 63.5mm | NS | Wood | |
SB-501654-NS | 3 Flute Solid Carbide Tapered Ball Nose 1/16” Nano Shield | 3 | 1/4“ / 6.35mm | 1” / 25.4mm | 40IPM / 1000mm/min | 20IPM / 500mm/min | 0.0039“ / 0.099mm | 5.4° | 1/16” / 1.6mm | 2 -1/2“ / 63.5mm | NS | Wood | |
SB-7510 | 3 Flute Surfacing Bit 1” | 3 | 1/4“ / 6.35mm | 1” / 25.4mm | 17/64“ / 6.7mm | 80IPM / 2000mm/min | 25IPM / 600mm/min | 0.06” / 1.524mm | 1-21/32“ / 42.07mm | N/A | Wood |
