| SKU / Image | Name | Flutes | Shank Diameter | Cut Diameter | Cutting Height | Feed Rate | Plunge Rate | Cut Depth | Degree | Tip | Overall Length | Coating | Best used for |
| Inches / mm | Inches / mm | Inches / mm | IPM mm/s | IPM mm/s | Inches / mm | Inches / mm | Inches / mm | ||||||
SB-603254-DC | 3 Flute Ball Nose Solid Carbide Tapered 1/32“ Diamond Carbon | 3 | 1/4” / 6.35 | 1“ / 25.4 | 40 / 16.932 | 20 / 8.466 | 0.0078” / 0.19812 | 1/32“ / 0.7937 | 2 -1/2” / 63.5 | DC | Plastic, Soft Metals |
