sharkbits
TOOL CHART
Download this convenient chart to have it on hand
SKU / Image Name Flutes Shank Diameter Cut Diameter Cutting Height Feed Rate Plunge Rate Cut Depth Degree Tip Overall Length Coating Best used for
SB-603254-DC
3 Flute Ball Nose Solid Carbide Tapered 1/32“ Diamond Carbon 3 1/4” / 6.35mm 1“ / 25.4mm 40IPM / 1000mm/min 20IPM / 500mm/min 0.0078” / 0.198mm 1/32“ / 0.8mm 2 -1/2” / 63.5mm DC Plastic, Soft Metals
SB-1018-DC
1 Flute Upcut Solid Carbide 1/8“ Diamond Carbon 1 1/4” / 6.35mm 1/8“ / 3.175mm 5/16” / 7.9mm 80IPM / 2000mm/min 25IPM / 600mm/min 0.0312“ / 0.792mm 2 -1/2” / 63.5mm DC Plastic, Soft Metals
SB-0514-DC
1 Flute Upcut Solid Carbide 1/4“ Diamond Carbon 1 1/4” / 6.35mm 1/4“ / 6.35mm 3/4” / 19.5mm 80IPM / 2000mm/min 25IPM / 600mm/min 0.0625“ / 1.588mm 2 -1/2” / 63.5mm DC Plastic, Soft Metals
SB-10518-DC
2 Flute Upcut Solid Carbide 1/8“ Diamond Carbon 2 1/4” / 6.35mm 1/8“ / 3.175mm 1/2” / 12.7mm 80IPM / 2000mm/min 25IPM / 600mm/min 0.03125“ / 0.794mm 2 -1/2” / 63.5mm DC Plastic, Soft Metals
SB-1018-DC
2 Flute Upcut Solid Carbide 1/4“ Diamond Carbon 2 1/4” / 6.35mm 1/4“ / 6.35mm 3/4” / 19.5mm 80IPM / 2000mm/min 25IPM / 600mm/min 0.0625“ / 1.588mm 2 -1/2” / 63.5mm DC Plastic, Soft Metals
SB-7014-DC
3 Flute High Helix Solid Carbide 1/4“ Diamond Carbon 3 1/4” / 6.35mm 1/4“ / 6.35mm 3/4” / 19.5mm 80IPM / 2000mm/min 25IPM / 600mm/min 0.0625“ / 1.588mm 2 -1/2” / 63.5mm DC Plastic, Soft Metals
SB-603254-NS
3 Flute Solid Carbide Tapered Ball Nose 1/32“ Nano Shield 3 1/4” / 6.35mm 1“ / 25.4mm 40IPM / 1000mm/min 20IPM / 500mm/min 0.0078” / 0.198mm 1/32“ / 0.8mm 2 -1/2” / 63.5mm NS Wood
SB-501654-NS
3 Flute Solid Carbide Tapered Ball Nose 1/16“ Nano Shield 3 1/4” / 6.35mm 1“ / 25.4mm 40IPM / 1000mm/min 20IPM / 500mm/min 0.0039” / 0.099mm 1/16“ / 1.6mm 2 -1/2” / 63.5mm NS Wood
SB-8516-NS
2 Flute Upcut Solid Carbide Ball Nose 1/16“ Nano Shield 2 1/4” / 6.35mm 1/16“ / 1.58mm 1/4” / 6.35mm 30IPM / 750mm/min 10IPM / 250mm/min 0.0154“ / 0.391mm 2 -1/2” / 63.5mm NS Wood
SB-1518-NS
2 Flute Upcut Solid Carbide Ball Nose 1/8“ Nano Shield 2 1/4” / 6.35mm 1/8“ / 3.175mm 1/2” / 12.7mm 50IPM / 1300mm/min 15IPM / 375mm/min 0.0312“ / 0.794mm 2 -1/2” / 63.5mm NS Wood
SB-9014-NS
2 Flute Upcut Solid Carbide Ball Nose 1/4“ Nano Shield 2 1/4” / 6.35mm 1/4“ / 6.35mm 1/2” / 12.7mm 50IPM / 1300mm/min 15IPM / 375mm/min 0.0625“ / 1.588mm 2 -1/2” / 63.5mm NS Wood
SB-2014-NS
2 Flute Downcut Solid Carbide 1/4“ Nano Shield 2 1/4” / 6.35mm 1/4“ / 6.35mm 3/4” / 25.4mm 80IPM / 2000mm/min 25IPM / 600mm/min 0.0625“ / 1.588mm 2 -1/2” / 63.5mm NS Wood
SB-2518-NS
2 Flute Downcut Solid Carbide 1/8“ Nano Shield 2 1/4” / 6.35mm 1/8“ / 3.175mm 1/2” / 12.7mm 80IPM / 2000mm/min 25IPM / 600mm/min 0.0312“ / 0.794mm 2 -1/2” / 63.5mm NS Wood
SB-6518-NS
10 Flute Diamond Cutter Carbon Fiber Solid Carbide Nano Shield 10 1/4“ / 6.35mm 1/8” / 3.175mm 3/4“ / 19.5mm 60IPM / 1500mm/min 30IPM / 750mm/min 0.0312” / 0.794mm 2 -1/2“ / 63.5mm NS Carbon Fiber
SB-10014-NS
2 Flute Straight Solid Carbide 1/4” Nano Shield 2 1/4“ / 6.35mm 1/4” / 6.35mm 3/4“ / 19.5mm 80IPM / 2000mm/min 25IPM / 600mm/min 0.0625” / 1.588mm 2 -1/2“ / 63.5mm NS Plastic
SB-9518-NS
2 Flute Straight Solid Carbide 1/8” Nano Shield 2 1/4“ / 6.35mm 1/8” / 3.175mm 1/2“ / 12.7mm 80IPM / 2000mm/min 25IPM / 600mm/min 0.0312” / 0.794mm 2 -1/2“ / 63.5mm NS Plastic
SB-8014-NS
2 Flute Compression Solid Carbide Bit 1/4” Nano Shield 2 1/4“ / 6.35mm 1/4” / 6.35mm 7/8“ / 22.2mm 40IPM / 1000mm/min 20IPM / 500mm/min 0.0625” / 1.588mm 2 -1/2“ / 63.5mm NS Laminates
SB-4000530-NS
Engraving Bit Solid Carbide 30 Degree 1 1/4” / 6.35mm 0.440“ / 11.2mm 40IPM / 1000mm/min 20IPM / 500mm/min 0.1” / 2.540mm 30° 0.005“ / 0.1mm 2 -1/4” / 57.15mm NS Plastic, Wood, Soft Metal
SB-4502545-NS
Engraving Bit Solid Carbide 45 Degree 1 1/4“ / 6.35mm 0.272” / 7.0mm 40IPM / 1000mm/min 20IPM / 500mm/min 0.003“ / 0.079mm 45° 2 -1/4” / 57.15mm NS Plastic, Wood, Soft Metal
SB-11514-NS
3 Flute V Groove Solid Carbide 60 Degree 1/4“ Nano Shield 3 1/4” / 6.35mm 1/4“ / 6.35mm 7/32” / 5.6mm 40IPM / 1000mm/min 20IPM / 500mm/min 0.0625“ / 1.588mm 60° 2” / 50.8mm NS Wood
SB-3060
2 Flute V Groove Solid Carbide 60 Degree 2 1/4“ / 6.35mm 1/2” / 12.7mm 7/16“ / 11.1mm 40IPM / 1000mm/min 20IPM / 500mm/min 0.125” / 3.175mm 60° 2“ / 50.8mm N/A Wood
SB-3590
2 Flute V Groove Solid Carbide 90 Degree 2 1/4” / 6.35mm 1/2“ / 12.7mm 3/8” / 9.5mm 40IPM / 1000mm/min 20IPM / 500mm/min 0.125“ / 3.175mm 90° 2” / 50.8mm N/A Wood
SB-7510
3 Flute Surfacing Bit 1“ 3 1/4” / 6.35mm 1“ / 25.4mm 17/64” / 6.7mm 80IPM / 2000mm/min 25IPM / 600mm/min 0.06“ / 1.524mm 1-21/32” / 42.07mm N/A Wood
*Please note that default settings are to be adjusted according to what material, speeds/feeds that you are using. Use theses libraries as a starting point for your projects. Use at your own risk.
sharkbits.1672774976.txt.gz · Last modified: 2024/08/05 15:15 (external edit)
