docs:software:vectric
Vectric Aspire, Cut2D, VCarve Post Processor to support OpenBuilds BlackBox and OpenBuilds Machines
You can use any of Vectric's CAM applications to generate G-Code for your machine. Simply select the correct Post Processor from the list:
1. Latest versions of Vectric applications
Select the relevant “OpenBuilds Grbl (mm/inch)” Post processor from the list
2. Older versions of Vectric applications
2.1 Option 1: Install the Post Processors
You can download and install our Post processors:
2.2 Option 2: Use the included Grbl Post processors
Select the “Grbl-mm” or “Grbl-inch” Post processor if the “OpenBuilds Grbl (mm/inch)” post is not available in your version. (Note: May sometimes include commands that is not 100% Grbl compatible - you would have to manually edit out M6 and other toolchange commands for example. Best to update to the latest versions, or install the Post Processors if possible)
docs/software/vectric.1670939612.txt.gz · Last modified: 2024/08/05 15:15 (external edit)
