docs:software:rhinocam_visualcam
Configure RhinoCAM / VisualCAM to support OpenBuilds BlackBox and OpenBuilds Machines
1. Download the Post Processors
Included are the two posts (Inch and Millimeter) that RhinoCAM 2024 and VisualCAD/CAM 2024 customers can use.
2. Install the Post Processors
Please follow these steps to install your customized post processor for use with your product version
Use the Windows File explorer to go to your Program Data folder. This is typically called ProgramData and you can find it on your system drive - usually the C:\ drive. This folder is hidden, so you’ll only see it if you show hidden files set in your operating system. Now go to ProgramData/MecSoft Corporation/2024 product/POSTS/MILL/SPM/ folder Copy the customized post to this folder Bring up your product and you should be able to use your customized post-processor in the list of available posts.
docs/software/rhinocam_visualcam.1725906864.txt.gz · Last modified: 2024/09/09 18:34 by admin
