| Green Wire | Earth |
| White Wire | Neutral |
| Black Wire | Live |
OpenBuilds® PowerCase V1.9 provides mounting holes on both ends that allows you to mount your power supply.
Using M5 x 8mm Screws with M5 Drop-in Tee Nuts for mounting
Insert M5 x 8mm Screw through mounting hole, and install a Drop In Tee Nut behind it
Attach to any V-Slot / C-Beam extrusion - for example one of our Tables
