docs:powercase-v1.9:start
OpenBuilds® PowerCase V1.9
Assembly Instructions
2. Attach the Front Panel Spacers
3. Attach the Front Panel to the Main Board
4. Main Board / Front Panel assembly
Make sure your completed sub assembly matches the image below
5. Attach the Power Supply
Green Wire Earth
White Wire Neutral
Black Wire Live
6. Attach the two Side Panels
7. Attach the Bottom Panel
Using 3pc x M3 x 6mm screws and 2pc x M4 x 4mm screws, attach the Bottom panel as shown
8. Attach the Top Panel
Using 3pc x M3 x 6mm screws attach the Top panel as shown
9. Attach the Mounting Panel
Using 2pc x M4 x 4mm screws attach the Mounting panel to the back of the Power Supply as shown
10. Complete!
Power on your creativity!
docs/powercase-v1.9/start.1670271788.txt.gz · Last modified: 2024/08/05 15:15 (external edit)
