docs:xyzprobe:wiringgeneric
Connecting OpenBuilds® XYZ Probe Plus to a CNC Controller
The OpenBuilds XYZ Probe Plus can be wired to almost any CNC controller with a Probe input. You just need to connect a minimum of two wires, or 3 for optimum performance:
Pinout
Pin on Probe connector Recommended Wire Color Pin on your controller Notes
GND Black GND Ground connection for signal and power
V+ Red VCC/V+ Optional 3.3v, 5v or 24v power source to match the required input voltage of your controller's input pin. If your controller does not have this available, you can leave this disconnected and the probe will still work. The power is used for the LEDs and noise filtering circuitry
SIG Blue PROBE IN Probe input signal pin which is read by your controller to determine if the endmill is making a connection to the Plate (which is in turn connected to GND, completing the circuit)
Wiring Examples
Follow color code indicators along with the Pinout table above
Controller Notes
Spark Concept xPro v3
xPro v3
Connect GND, Signal and 5V and Set $6=0 in Grbl Settings
Spark Concept xPro v4
xPro v4
Connect GND, Signal and optionally 5V, Set $6=0 in Grbl Settings
docs/xyzprobe/wiringgeneric.txt · Last modified: 2020/06/04 17:15 by admin
