docs:blackbox:install-drivers
The OpenBuilds BlackBox uses an FTDI USB Interface. In order to use it on your computer, you may need to install device drivers.
  • More modern operating systems may be able to use the Blackbox directly without additional drivers,
If it fails to install drivers automatically, you can download and install the drivers for your operating system
https://www.ftdichip.com/Drivers/VCP.htm
docs/blackbox/install-drivers.txt · Last modified: 2020/06/09 14:16 by admin
