docs:blackbox:connect-micro-limit
3.4.1 Connecting BlackBox 4X to Limit Switches
Use a 2-core cable to wire up our regular microswitches
IMPORTANT WARNING: Note: Incorrect wiring can short V+ to GND causing damage to your controller: Double check wiring before powering on. We recommend using 2-core wiring only for this type of switch to avoid accidentally shorting V+. Only connect SIG and GND pins on the BlackBox.
If you need a more EMI proof solution, consider upgrading to OpenBuilds Xtension Limit Switches
docs/blackbox/connect-micro-limit.txt · Last modified: 2020/07/17 15:16 by admin
