docs:blackbox:connect-4-wire-laser
3.3.3 Connecting BlackBox 4X to a 24v Laser Module
TIP: Remove the Relay Mode jumper to prevent the relay from clicking on/off rapidly during laser operations
If you would like to use both a Laser, and the IoT relay, See: Connecting both an IOT Switching Relay for a Router, and a Laser, to the BlackBox
docs/blackbox/connect-4-wire-laser.txt · Last modified: 2021/01/28 19:38 by admin
